How does one switch the ANT_OFF GPIO pin on the LIV3F?
CHr
Sasha1
Did you ever figure this out? I am looking at the same thing. Perhaps it is controlled only by the module when it goes into powerdown and is not able to be changed via a command?
Similar devices it relates to low power and power down modes, for example when put in a sleep or intermittent wake cycle.
Signal used to gate LNA or external antenna bias
Thanks for the super quick response!! So controlled by the module only, correct? Not able to be controlled via software command over UART?
