Help on USB Memory example
animev09
Posted on July 11, 2007 at 12:14
4 REPLIES 4
animev09
Posted on May 17, 2011 at 09:44
When I test the USB Memory example on MCBSTR9 board, I need both the Ulink2 cable and usb cable connect the board with my pc to work. When I take out Ulink2 cable, and left only usb cable connect board to my pc, the program not run anymore. My PC (window xp) not recognize usb device.
So how I can run the program with only usb cable?
Thank you
JP
animev09
Can anyone show me how to make it run without Ulink2?
Thank you
John
animev09
I got answer from Keil forum. My board MCBSTR9 uses 150 mA and each usb device gives 100 mA, so it needs 2 usb cable connect to run.
andy_ry
Just take out Ulink2 JTAG connector...
:o
