Help me identify SMD componet C511
IVilk.1
An expensive device is being repaired, in one of the voltage generation circuits there is an element ST E CUG C511 having a SMB case. On the diagram, it is denoted by the abbreviation CR, which is denoted elsewhere by the Zener dione. The device was produced in 2006, the searching for marking did not give any results.
SMBJ16A
https://www.st.com/resource/en/datasheet/smbj16a.pdf
SMBJ16A
