Error: stopped on undefined memory access
lseletron
Posted on May 09, 2007 at 02:26
lseletron
I am emulating 72325J6 with DVP3 and using the Cosmic compiler.
I am getting this error:
Error: undefined memory access at XXXX
XXXX sometimes is random, sometimes is permanent and is 0x1ee7 (map file says it is in the debug section)
I have in one of the external interrupt ISRs this code:
@interrupt void Ex3Int(void)
DisableInterrupts;
TAOC1R=SomeValue;
TAOC2R=790;//When this is commented, no problems
EnableInterrupts;
When I comment the line setting TAOC2R, the program runs OK.
Why does this happen?
