booting STR9
gregh
Posted on July 22, 2009 at 17:06
booting STR9
gregh
Posted on May 17, 2011 at 09:59
This is my first project with the STR9 and I am having my share of beginner problems. I'm using the HiTOP5 IDE, GNU tools and the Hitex Tanto JTAG connector. I have my program running successfully under the Tanto, but when I remove the Tanto and recycle the power the code does not appear to boot. When I reattach the Tanto I can verify that the code is still in flash memory. I can use a scope and verify that the reset is attached and working.
I am sure there is a simple cure for this problem. Have I overlooked something simple? I have no clue what to do next. Anyone have any advice.
