91x_vect.s does not change
mtraman
Posted on April 09, 2007 at 14:38
mtraman
Posted on May 17, 2011 at 09:40
Hi
i run programs from the ram.
i need to disable nested interrupts. i did this in 91x_vect.s but
whenever an interrupt occurs the program control goes to a specific flash location that looks exactly like the original 91x_vect.s.
right now the flash has a simple program with the original 91x_vect.s
what should i do to make changes in the 91x_vect.s to take effect.
thanks
vikram
