We're using the VL53L1X sensor and this will be sealed into our enclosure during the manufacturing process. Is there a humidity spec we need to be aware for the manufacturing process?
DAmer.1
The enclosure this will be going into will be sealed and any humidity present during the manufacturing process will be trapped within the enclosure. Is there a humidity spec we should be aiming for?
John E KVAM
If you read the datasheet, they say "Moisture sensitivity is level 3 (MSL) as described in IPC/JEDEC JSTD-020-C". I have no idea what that is or where to find it, but I'm guessing it will answer your questions. If not, ping me again and I will dig deeper.
  • john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
