Regarding PCM buffer data used in audio loop example of bluecoin
Dinakaran Palani
how can i store 1 second audio data using audio loop example
7 REPLIES 7
niccolò
Hi @Dinakaran Palani​ ,
if you follow the datapath of the audio signal you will find the audio buffer.
once you find it, you can store it in a long array until you have enough samples to make one second.
hope this helps,
Niccolò
Dinakaran Palani
Hi @niccolo.ruffini​
how frequently should I capture the data from pcm buffer to another buffer
the second one is how should I declare that buffer for storing one-second samples for the sampling rate 16000 for single-channel
if I declare an array of uint16_t[16000] if I do so I am getting excessive use of ram
you should capture data from the buffer every time it is full, otherwise you loose samples.
do you get the error even if you use the malloc?
Niccolò
Dinakaran Palani
how to do it
you can follow this link to check how to use the malloc function.
hope this helps
Niccolò
Dinakaran Palani
i tried allocating by using the snippet as shown in the example link I am not able to allocate 16000 memory location
What system are you using?
Niccolò
