LSM9DS1 I2C address identification
2017-06-22 12:56 AM
I am planning to use
LSM9DS1
9DoF sensor in our project.As per datasheet table #2, Least significant bit for I2C address is [SDO_ A/G or SDO_M ]= SA0.
From this information & Table#19, I will be able to identify I2C address for
Accelerometer and gyroscope.
How can I set address bit 1 of SAD[1]/SA1 to identify
Magnetic sensor
I2C address?Awaiting for earliest response.
Ritesh.
2017-09-04 5:11 AM
Hello Ritesh,
It seems like a typo in the datasheet Table 2 Pin description: SDO_M Pin #6 should set I2C LSB+1 of the device address (SA1) for the magnetometer while LSB (SA0) is always 0. So you can use this pin for your magnetometer identification. I'll ask for datasheet correction.
Petr
