LIS2DH12 INT1 open-drain?
christof
Posted on April 15, 2016 at 19:22
Is the INT1 pin of LIS2DH12 set to push-pull configuration per default? And if so, is it possible to set it to open-drain?
Note: I already set the INT1 to active-low - but open-drain would be necessary as well...
0 REPLIES 0
