2024-09-04 12:38 PM
I am using a LIS2DE12 to detect when a mechanical shock occurs to my device. The datasheet provides only nominal values for the sample rate and the sensitivity.
If worst case values are not available is there some characterization data which could provide some guidance?
Thank you.
2024-09-05 02:54 AM
Hi @Chip Weller ,
Yes, these data are available only in characterization report. If you are interested, you can contact the online support system at this link to request them.
2024-09-05 02:54 AM
Hi @Chip Weller ,
2024-09-05 04:21 AM
I certainly am interested, however your link did not work. It lead to a page not found display (404 error). I went directly to the support tab on the main ST site and tried to "open a case" but I got the same page not found.
I would try to tell ST about this web site issue, but it looks like I need to open a ticket to do that.
2024-09-05 04:23 AM
Hi @Chip Weller ,
It works for me, have you tried logging in with a different browser?
