Lidar interface and 2D scan
Sundar santhanam
I wanted to interface a lidar with stm controller and see the 2 dimensional mapping in a graph may be similar to frame grabber. Does stm have any tools for the same ? like to get the graph of scanned environment by a lidar
Thanks in advance!!!
John E KVAM
if you look for 2D-Lidar on st.com you will get to:
STSW-IMG017
2D LIDAR using multiple VL53L1X Time-of-Flight long distance ranging sensors.
This is my implementation of a 2D lidar. I'd start with this.
The code uses 1 STM32 Nucleo board and 9 VL53L1X sensors arrayed in a half circle.
Even if you don't use it like this, it will give you a solid example of what can be done.
There is also a YouTube video. Go to YouTube and you will find a video on what we did
2D LIDAR Using Multiple ST VL53L1X Time-of-Flight Sensors
Good luck
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
Thank you so much , also wanted to know that is this possible using single time of flight sensor rotating it in circular manner!
