Is the acceleration and jirescope sensors integrated in the pin compatible with the same?
MY��l
5 REPLIES 5
AvaTar
Lead
Your question is not comprehensible.
MY��l
Are the pins of the acceleration and gyroscope sensors compatible? So do you have the integrated model with the same pin structure? i need this problem a solutions. Thank you.
AvaTar
Lead
Ask ST FAEs or distributors diectly.
Volunteers on a public forum will usually not do the simple due diligence tasks you can easily do yourself.
I suggest you to use 6 axis modules which contains both axl and gyro. MEMS gyroscopes are rarely sold standalone.
thank you sir.
