Can you acquire data with another sensor (or from existing dataset), or does the acquisition need to be done with the ASM330LHHX?
Evelina CAMILLERI
Luca SEGHIZZI
Yes, it is possible using existing datasets. However, it is suggest to perform a dedicated data collection campaign for a better accuracy of the model.
Quality of data logs is a key point for Machine Learning based algorithms, since the model is built from the data. It is important to correctly acquire and label data. You can find a design tip document on our website, with some tips for a good AI algorithm realization. You can find the document at the following link: st.com/dt0139
Luca SEGHIZZI
