X-Nucleo-IDW01M1
bowsa2001
Posted on March 25, 2016 at 06:07
I have a X-Nucleo-IDW01M1 board on a Nucleo-F411re board. The board was working fine with some of the example projects. Suddenly it keeps going in and out of deep sleep with the red and blue LED going on and off. Tried to use AT command to set it back to factory default but no luck. Can you advise me how to recover the board?
Gerardo GALLUCCI
Posted on March 25, 2016 at 08:02
Hi Howard,
you can:
1 - force a factory reset (set GPIO0 high at startup)
2 - exit deep sleep (set GPIO6 high) and then disable deepsleep (AT+CFUN=0)
j
bowsa2001
Posted on March 25, 2016 at 14:13
Gerardo,
I was able to restore factory default by setting GPIO0 to high at startup.
Thank you!!!!
Posted on April 28, 2017 at 04:25
Hello Harris,
I would like to ask if you rebuilt the .bin for F411RE specially please.
Because the sample apps are only for F401RE?!
And which sample apps worked for you before please?!
Thanks & Best Regards,
Robert
