STEVAL-IDW001V1 documentation?
vneff
Posted on April 28, 2014 at 16:28
I just received a STEVAL-IDW001V1 eval module.  It is meant to connect to a Discovery F0 board, but intend on using it with a STM32F215 processor based device.  I haven't found much documentation about this eval board.  I have:
STEVAL-IDW001V1 - Wi-Fi daughterboard for STM32F0DISCOVERY
which includes a schematic and a general outline of what the board can do.  No specifics as to what the jumpers are for, what the important connections are, etc.
STEVAL-IDW001V1 Schematic diagram
This seems to have no relation to the eval board???
SPWF01Sx - Serial-to-Wi-Fi b/g/n intelligent modules
This does, at least, give pin-out for the WiFi module being evaluated alond with some min/max ratings.
And, the most useful so far:
SPWF01Sx AT Command set reference guide
Is there any detailed info on the eval board, or is this it?
Thanks for any additional info!
Vance
Gerardo GALLUCCI
Posted on May 05, 2014 at 12:21
Hi Vance,
we are working on st.com/wifimodules documentation. It will be more rich of informations from the end of May on.
- SPWF01S Datasheet -> go to www.st.com/wifimodules, click on SPWF01Sx, then ''Design Resources'' into new tab
- IDW001page:http://www.st.com/web/en/catalog/tools/PF260012 (again, click on ''Design Resources'')
In Attach:
-IDW001 HowTo
- SockServer HowTo
Thanks for feedbacks
________________
Attachments :
SPWF01Sx___Socket_Server.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0ei&d=%2Fa%2F0X0000000bmq%2FqQuJUohAQafLATflMqubVDecKW35zGMlUllBywbm.eg&asPdf=false
SPWF01Sx_and_STM32F0-Discovery.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1QC&d=%2Fa%2F0X0000000bmm%2Fw8MU4Vl4Y1RDXld9WADjkUcvMIG9SY3x_K8zB1V74ug&asPdf=false
artur
Posted on October 13, 2014 at 12:12
Welcome for the first time on this forum.
I try to use SPWF01S in my projects, unfortunately I met unsolvable problem for me.
I would like to ask you for the information, how to save a set of html pages to an IMG file (as in STEVAL-IDW001V1) so that it can be send to the module by a command AT + S.HTTPDFSUPDATE.
Which tool creates this file?
Best regards
Gerardo GALLUCCI
Posted on November 20, 2014 at 03:36
sorry for delay.
Please contact your local ST support. He will send you that tool. It builds an ''*.img'' file, starting from a directory containing target filesystem content.
jerry
