ST25DV04K PCB Antenna
GErma.1
Hi
I would tike to use the ST25DV04K NFC tag in a Lorawan end node based on the on the CMWX1ZZABZ-091 module.
Can you please provide more info on the ANT7-T-ST25DV04K reference design? I was not able to find the pcb documentation.
I addition to that, is there any material on pcb antenna that I can use ?
BR
Gilberto
PMill.1
Gilberto - I can help you with that question if still needed.
Pete
GErma.1
Hi
We have designed a board with an NFC from Molex (PN 146236-0031).
Any help on the utilization of the Molex antenna is welcome.
BR
Gilberto
