2026-05-21 7:54 AM
Does the ST67W611M1 (-B version) with PCB antenna have a built in rf switch? We want to programmatically or via pins switch between the PCB antenna and an external antenna.
2026-05-22 12:34 AM
Hi @Nkh
There is no internal switch in the module. The connector on the B version already includes a switch; however, this connector is intended for conducted RF measurements, not for connecting a second antenna.
The P version is designed for use with two antennas.
