SPWF04Sx - AT+S.FSL/FSP - app_fs status
yoann LBY
Posted on December 05, 2017 at 16:49
hi,
in the UM2114 V2.0 for cmd AT+S.FSL and AT+SFSP there is a note:
Note that Volume ID 3, Application Flash, when protected (
app_fs
status variable set to 2) does not show content files.
I don't see this variable nowhere!
How can i check this variable in the wifi module?
Yoann
Posted on December 05, 2017 at 17:07
Thank you Gerardo,
but AT+SSTS give nothing!
AT+S.STS
AT-S.List
AT-S.Var:nv_manuf=STMicroelectronics Inc.
AT-S.Var:nv_model=SPWF04SA
AT-S.Var:nv_serial=17111984
AT-S.Var:nv_wifi_macaddr=00:80:E1:BD:00:71
AT-S.Var:standby_time=10
AT-S.Var:standby_enabled=0
AT-S.Var:sleep_enabled=0
AT-S.Var:etf_mode=0
AT-S.Var:blink_led=1
AT-S.Var:ext_volume=0
AT-S.Var:ramdisk_memsize=16
AT-S.Var:aes128_key=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:61
AT-S.Var:user_desc=nonymous
AT-S.Var:python_script=3:/uPython_test.py
AT-S.Var:python_memsize=32
AT-S.Var:console_enabled=1
AT-S.Var:console_speed=115200
AT-S.Var:console_hwfc=0
AT-S.Var:console_echo=1
AT-S.Var:console_errs=2
AT-S.Var:console_winds=2
AT-S.Var:console_verbose=1
AT-S.Var:console_repeater=0x21
AT-S.Var:console_delimiter=0x2C
AT-S.Var:console_wind_off_low=0x00000000
AT-S.Var:console_wind_off_medium=0x00000000
AT-S.Var:console_wind_off_high=0x00000000
AT-S.Var:wifi_tx_msdu_lifetime=0
AT-S.Var:wifi_rx_msdu_lifetime=0
AT-S.Var:wifi_operational_mode=0x00000011
AT-S.Var:wifi_beacon_wakeup=1
AT-S.Var:wifi_beacon_interval=100
AT-S.Var:wifi_listen_interval=0
AT-S.Var:wifi_rts_threshold=3000
AT-S.Var:wifi_ssid=6C:65:62:65:6C:6C:79:31:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
AT-S.Var:wifi_ssid_len=8
AT-S.Var:wifi_txfail_thresh=5
AT-S.Var:wifi_dtim_period=1
AT-S.Var:wifi_add_tim_ie=0
AT-S.Var:wifi_region=1
AT-S.Var:wifi_ht_mode=1
AT-S.Var:wifi_channelnum=11
AT-S.Var:wifi_opr_rate_mask=0x003FFFCF
AT-S.Var:wifi_bas_rate_mask=0x0000000F
AT-S.Var:wifi_mode=1
AT-S.Var:wifi_auth_type=0
AT-S.Var:wifi_atim_window=0
AT-S.Var:wifi_powersave=0
AT-S.Var:wifi_tx_power=18
AT-S.Var:wifi_rssi_thresh=0
AT-S.Var:wifi_rssi_hyst=0
AT-S.Var:wifi_ap_idle_timeout=120
AT-S.Var:wifi_beacon_loss_thresh=10
AT-S.Var:wifi_priv_mode=0
AT-S.Var:wifi_wep_keys[0]=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
AT-S.Var:wifi_wep_keys[1]=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
AT-S.Var:wifi_wep_keys[2]=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
AT-S.Var:wifi_wep_keys[3]=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
AT-S.Var:wifi_wep_key_lens=00:00:00:00
AT-S.Var:wifi_wep_default_key=0
AT-S.Var:wifi_wpa_psk_raw=74:CF:1B:3F:23:69:3E:2E:1B:29:83:C6:75:42:8F:F3:6F:31:2C:AA:29:EB:E2:AB:87:F7:F9:83:8C:D0:98:19
AT-S.Var:wifi_wpa_psk_text=SRRXTW6N
AT-S.Var:wifi_eap_identity=identity
AT-S.Var:
mailto:wifi_eap_anon_identity=anonymous@identity.org
AT-S.Var:wifi_eap_passwd=password
AT-S.Var:wifi_eap_type=0
AT-S.Var:wifi_eap_skip_datechecks=0
AT-S.Var:wifi_wps_walk_time=120
AT-S.Var:wifi_wps_pin=1234567
AT-S.Var:ip_sock_memsize=1
AT-S.Var:ip_sock_threshold=0
AT-S.Var:ip_dhcp_lease_time=120
AT-S.Var:ip_macfilter=00:00:00:00:00:00
AT-S.Var:ip_num_clients=5
AT-S.Var:ip_allow_port_scans=1
AT-S.Var:ip_use_v6=1
AT-S.Var:ip_use_dhcpd=1
AT-S.Var:ip_use_httpd=1
AT-S.Var:ip_use_tftpd=1
AT-S.Var:ip_use_dhcpc=2
AT-S.Var:ip_hostname=iwm-BD-00-71
AT-S.Var:ip_apdomainname=captiveportal.net
AT-S.Var:ip_apredirect=firstset.html
AT-S.Var:ip_ipaddr=192.168.0.50
AT-S.Var:ip_netmask=255.255.255.0
AT-S.Var:ip_gw=192.168.0.1
AT-S.Var:ip_dns1=208.67.222.222
AT-S.Var:ip_dns2=208.67.220.220
AT-S.Var:ip_local=0:0:0:0:0:0:0:0
AT-S.Var:ip_dns1v6=0:0:0:0:0:0:0:0
AT-S.Var:ip_dns2v6=0:0:0:0:0:0:0:0
AT-S.Var:ip_dhcp_timeout=20
AT-S.Var:ip_ntp_server1=ptbtime1.ptb.de
AT-S.Var:ip_ntp_server2=ntp0.ipv6.fau.de
AT-S.Var:ip_ntp_refresh=3600
AT-S.Var:ip_ntp_startup=1
AT-S.Var:ip_mdns_domain_name=SPWF04S-Default
AT-S.Var:ip_mdns_device_name_ttl=120
AT-S.Var:ip_mdns_services_name=SPWF04S-WebSrv SPWF04S-TFTPSrv
AT-S.Var:ip_mdns_services_prot=_http._tcp _tftp._udp
AT-S.Var:ip_mdns_services_keys=dev1 dev2
AT-S.Var:ip_mdns_services_vals=number1 number2
AT-S.Var:ip_mdns_services_port=80 69
AT-S.Var:ip_mdns_services_ttl=120 60
AT-S.Var:ip_mdns_startup=01:01
AT+S.STS=app_fs give a result : AT-S.Var:app_fs=1.
and i just find explanation in the UM2114 V2.0 Table 9: Status variables!
thanks
Yoann
5 REPLIES 5
Gerardo GALLUCCI
Posted on December 05, 2017 at 16:56
AT+S.STS (full list) or
AT+S.STS=app_fs (that variable)
Thank you Gerardo,
AT+S.STS
AT-S.List
AT-S.Var:etf_mode=0
AT-S.Var:
thanks
Yoann
Posted on December 05, 2017 at 17:13
Full list you wrote is the output of AT+S.GCFG, and not AT+S.STS
Posted on December 05, 2017 at 17:26
i confirm i use cmd AT+S.STS.
it's include at the beginning of the copy/pass in the previous message (AT+S.STS)!
Yoann
Posted on December 06, 2017 at 09:08
hi,
i reloaded FW1.1.0 and AT+SSTS give good response now 'status variables'.
Something bad before...Mea culpoa ;)
AT+S.STS
AT-S.List
AT-S.Var:build=171117-0328fe3-SPWF04S
AT-S.Var:fw_version=1.1.0
AT-S.Var:boot_version=1.0
AT-S.Var:var_version=2
AT-S.Var:app_fs=1
AT-S.Var:ram_fs=1
AT-S.Var:user_fs=0
AT-S.Var:extvol_fs=0
AT-S.OK
