spwf01 module Timing Issue
basavanagouda
Posted on September 01, 2016 at 12:45
I observed followings while communicating between two
spwf01
modules:
  • At the Client side when its try to connect to server I’m using AT+S.SOCKON command to connect.
  • In this command I can pass “ind�? parameter which can indicate data arrival at the client side with “+WIND:55:Pending Data�? on UART interrupt .
  • Client side it is taking 500ms to receive WIND:55:Pending Data: interrupt.
  • Server to client data transmission it takes only 5 to 6ms.
Please suggest how to solve this time delay at the client side.
Thank you
Basavanagouda
18 REPLIES 18
Gerardo GALLUCCI
Posted on September 02, 2016 at 18:00
Please post some other info: FW version, status dump, average RTT of the network, kind of socket used, etc...
basavanagouda
Posted on September 06, 2016 at 10:42
Thank you for your reply
Below details I got for AT&V command, and I'm using TCP protocol for communication.
+D:24:WiFi Up:4.2
Dumping All Configuration Keys:
nv_manuf = ST
nv_model = SPWF01SA1
nv_serial = 5114D22308
nv_wifi_macaddr = 00:80:E1:B4:AF:6A
blink_led = 0
wind_off_low = 0x00000000
wind_off_medium = 0x00000000
wind_off_high = 0x00000000
user_desc = anonymous
escape_seq = at+s
localecho1 = 0
console1_speed = 115200
console1_hwfc = 0
console1_enabled = 1
sleep_enabled = 0
standby_enabled = 0
standby_time = 10
wifi_tx_msdu_lifetime = 0
wifi_rx_msdu_lifetime = 0
wifi_operational_mode = 0x00000011
wifi_beacon_wakeup = 1
wifi_beacon_interval = 100
wifi_listen_interval = 0
wifi_rts_threshold = 100
wifi_ssid = 4C:41:4E:44:44:4F:4F:52:31:41:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
wifi_ssid_len = 11
wifi_channelnum = 6
wifi_opr_rate_mask = 0x00003FCF
wifi_bas_rate_mask = 0x0000000F
ifi_mode = 1
ifi_auth_type = 0
ifi_atim_window = 0
ifi_powersave = 0
ifi_tx_power = 18
ifi_rssi_thresh = 0
ifi_rssi_hyst = 0
ifi_ap_idle_timeout = 120
ifi_beacon_loss_thresh = 10
ifi_priv_mode = 0
ifi_wep_keys[0] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
fi_wep_keys[1] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
fi_wep_keys[2] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
i_wep_keys[3] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
i_wep_key_lens = 00:00:00:00
i_wep_default_key = 0
i_wpa_psk_raw = 7A:35:61:54:E0:E1:89:E8:14:95:DB:57:0E:BA:6F:71:FC:BB:33:CD:77:E3:43:76:B8:6E:22:4D:56:39:E7:92
_wpa_psk_text = LANDDOOR1AP
se_dhcp = 2
se_httpd = 1
tu = 1500
ostname = iwm-B4-AF-6A
pdomainname = captiveportal.net
paddr = 4.1
etmask = 0
w = 0.1
ns = 0.1
ttp_get_recv_timeout = 3000
cp_timeout = 20
ckd_timeout = 250
Thank you
Basavanagouda.
basavanagouda
Posted on September 06, 2016 at 10:45
I have observed Station mode module is taking more time(40sec to 1minute ) to search the access point module.
How to reduce this time?
kindly give suggestion.
Thank you
Basavanagouda.
Gerardo GALLUCCI
Posted on September 06, 2016 at 10:58
AT+S.STS also
As many info you can share, as fast we can solve...
ps: check your UART driver. you are loosing a lot of bytes. consider to use an rs232/usb converter at this early stage, removing external MCU.
basavanagouda
Posted on September 06, 2016 at 11:41
Hi
Below information at the Station mode module.
# Status & Statistics:
#  version = 141106-0950875-SPWF01S
#  reset_reason = 2
#  conf_flag = 5
#  system_uptime = 571
#  system_sleeptime = 0
#  gpio_enable = 0
#  captiveportal = 0
#  wifi_state = 10
#  wifi_bssid = 00:80:E1:B4:85:06
#  wifi_aid = 1
#  wifi_channelnum = 6
# wifi_sup_rate_mask = 0x003FFFCF
#  wifi_bas_rate_mask = 0x00000000
# wifi_chan_activity2 = 0x00003FFF
#  wifi_max_tx_power = 18
# wifi_reg_country = GB
# wifi_dtim_period = 0
# wifi_sleeping = 1
# wifi_num_assoc = 0
# ip_ipaddr = 192.168.4.2
# ip_netmask = 255.255.255.0
# ip_gw = 192.168.4.1
# ip_dns = 192.168.4.1
# ip_sock_open = 1
# ip_sockd_port = 0
# free_heap = 20568
# min_heap = 20008
# current_time = 1054
OK
Below information at the Access mode module.
# Dumping All Configuration Keys:
#  nv_manuf = ST
#  nv_model = SPWF01SA1
#  nv_serial = 5114D22308
#  nv_wifi_macaddr = 00:80:E1:B4:AF:6A
#  blink_led = 0
#  wind_off_low = 0x00000000
#  wind_off_medium = 0x00000000
#  wind_off_high = 0x00000000
#  user_desc = anonymous
#  escape_seq = at+s
#  localecho1 = 0
#  console1_speed = 115200
#  console1_hwfc = 0
#  console1_enabled = 1
#  sleep_enabled = 0
#  standby_enabled = 0
#  standby_time = 10
#  wifi_tx_msdu_lifetime = 0
#  wifi_rx_msdu_lifetime = 0
#  wifi_operational_mode = 0x00000011
#  wifi_beacon_wakeup = 1
#  wifi_beacon_interval = 100
#  wifi_listen_interval = 0
#  wifi_rts_threshold = 100
#  wifi_ssid = 4C:41:4E:44:44:4F:4F:52:31:41:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_ssid_len = 11
#  wifi_opr_rate_mask = 0x00003FCF
#  wifi_bas_rate_mask = 0x0000000F
#  wifi_mode = 3
#  wifi_auth_type = 0
#  wifi_atim_window = 0
#  wifi_powersave = 0
#  wifi_tx_power = 18
#  wifi_rssi_thresh = 0
#  wifi_rssi_hyst = 0
#  wifi_ap_idle_timeout = 120
#  wifi_beacon_loss_thresh = 10
#  wifi_priv_mode = 0
#  wifi_wep_keys[0] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_keys[1] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_keys[2] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_keys[3] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_key_lens = 00:00:00:00
#  wifi_wep_default_key = 0
#  wifi_wpa_psk_raw = 7A:35:61:54:E0:E1:89:E8:14:95:DB:57:0E:BA:6F:71:FC:BB:33:CD:77:E3:43:76:B8:6E:22:4D:56:39:E7:92
#  wifi_wpa_psk_text = LANDDOOR1AP
#  ip_use_dhcp = 2
#  ip_use_httpd = 1
#  ip_mtu = 1500
#  ip_hostname = iwm-B4-AF-6A
#  ip_apdomainname = captiveportal.net
#  ip_ipaddr = 192.168.4.1
#  ip_gw = 192.168.0.1
#  ip_dns = 192.168.0.1
#  ip_http_get_recv_timeout = 3000
#  ip_dhcp_timeout = 20
#  ip_sockd_timeout = 250
#  reset_reason = 2
#  conf_flag = 5
#  system_uptime = 368
#  gpio_enable = 0
#  captiveportal = 0
#  wifi_state = 5
#  wifi_bssid = 00:00:00:00:00:00
#  wifi_aid = 0
#  wifi_channelnum = 0
#  wifi_sleeping = 0
#  ip_ipaddr = 0.0.0.0
#  ip_netmask = 0.0.0.0
#  ip_gw = 0.0.0.0
#  ip_dns = 0.0.0.0
#  ip_sock_open = 0
#  ip_sockd_port = 0
#  free_heap = 21544
#  min_heap = 20008
#  current_time = 495
OK
Basvanagouda
Gerardo GALLUCCI
Posted on September 06, 2016 at 12:11
you are using a 2 years old release.
First of all, please update to FW3.5
basavanagouda
Posted on September 06, 2016 at 12:22
Oops:(
Can you please share the latest version firmware and Updating procedure from UART.
It will help me lot.
Thank you
Basavanagouda
basavanagouda
Posted on September 06, 2016 at 12:36
If I update the firmware version, above issue can be resolved?
it already took lot of my time to solving it.
Please let me, If its can solve my issue it will help me lot
Basavanagouda
Gerardo GALLUCCI
Posted on September 06, 2016 at 13:20
Try new FW and let me know.
E.g. FW3.5 works better when looking for hidden networks
