Commands AT problem i nucleo LRWAN1 & Nucleo L073RZ
Bjere.1
My Problem is ; i can't extract properly the APPEUI from inucleo LRWAN1 ( there is no stickers on module)
I tried many times to communicate with AT commands but i have issue with it.
I configure terminal Tera Term ( 115200 bauds)
I tried with widows' command ( good for EUI) but i receive 00 00 00 00 00 00 00 00 for APP EUI ( this is not correct for a TTN' application).
I followed the UM2587 document.
Jérémy Bolloré
GAM
Hi Jeremy,
I guess your LoRa-Baord is labeld WM-SG-SM-42_Shield manufacterd from USI.
On https://github.com/USIWP1Module/USI_I-NUCLEO-LRWAN1 you will find in
WM-SG-SM-42 AT Command Reference Manual rev.2.6_20200225.pdf
on Page 8 how to connect to an FTD-Interface.
You can use the Shield standalone (powerd by the FTD-Interface) and dsend the AT-Command via Tera Term
Best regards
Georg Muench
