Adding Character to gatt_db ( STEVAL-BNC002V1)
MSENE.1
Hello everyone i'm discovering BLE communication through STEVAL-BNC002V1.
Then i want to add new characteristics with fields calculated with values from sensors.
I read the documentation but i can't understand the function aci_gatt_db_add_char.
I will be really happy to get help.
Thank you
4 REPLIES 4
Scott Löhr
Senior II
Really? Are you a Bot just spamming this community?
How is it possible that you do not have a more explicit, detailed question if you have really studied the sample application and the plethora of documentation of how to use the BLE API?
MSENE.1
Thank you,i'll try to bring a more explicit question.
PS:I'm not a bot i'm what we call a nerby.
Scott Löhr
Senior II
Good show - you have a much higher chance of getting an answer or at least responses to a question or problem that is as specific as possible and shows that you tried to use the ST example app and/or documentation.
Winfred LU
Is it a typo of aci_gatt_add_char ?
This function is used to add a characteristic to a service.
