2022-11-01 2:23 PM
I would like to upload 2 different ML models to the microcontroller and swap between which one I use for classification (within the microcontroller)
However, the code seems only to generate the code for one model properly. Is this correct? or should it generate the code for both?
Are there any examples of using multiple models?
2022-11-02 8:55 AM
Hello KSOdin2,
you can find an example with ultrasound classifier & Human Activity Recognition in https://www.st.com/en/embedded-software/fp-ai-monitor1.html
best regards
Laurent
2022-11-02 8:55 AM
Hello KSOdin2,
best regards
Laurent
2022-11-02 10:08 AM
Brill! Thanks Laurent
