Can't STSW-IMG035 be used for VL53L5CX?
Philister
Hi
I want to use the VL53L5CX on  STSW-IMG035, but I found that the sensor initialization in the source code only supports VL53L7CX and VL53L8CX.
I checked the source code of STSW-IMG023 and found some differences in the sensor initialization process, so I can't directly use the code of STSW-IMG035 for VL53L5CX, is that right?
But according to the document "GestureEVK_UG.pdf" in STSW-IMG035, it is mentioned that VL53L5CX can be used, and there are many comments in STSW-IMG035 about VL53L5CX(although they may be wrong), so I think that for some reason, the support for VL53L5CX was removed in the B case?
How should I use VL53L5CX to develop my gesture recognition cases with STSW-IMG035?
Sincerely,
Phil
labussiy
Hi @Philister,
VL53L5CX is no more promoted, that's why it's not in the web page of the solution.
But you can evaluate the solution with this sensor.
Yann
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
Julian E.
Hello @Philister,
Our expert regarding this subject is currently out of office.
He should come back in around a week.
Feel free to ping this thread again if you don't receive any answer.
Have a good day,
Julian
labussiy
Hi @Philister,
Yann
