2015-10-07 5:48 AM
I am using
Universal Debug Engine v4.02.07
for programming the flash with SPC560D MCU withPLS USB/JTAG adapter
. Where can I find the checksum value for the obj file (.elf or .hex or .out)? Which menu of the tool has this information listed? any document for the UDE tool?Thanks in advance.Mike.2015-10-09 1:52 AM
Is there any generic tool available for knowing the checksum value of the generated output file (.elf or .hex or .bin etc)?
Thanks.Mike.2015-10-12 3:04 AM
Hello Mike ,
Sorry for the late answer , my alert settings was brokenyou can use cksum <FILENAME> to generate a checksum on defined file.or md5sum.exe (cygwin tools)i am checking on PLS Side Best regards Erwan2015-10-13 6:12 AM
Hello Erwan,
Any updates on the PLS side? Whether the two executables mentioned below are available with SPC5Studio?Thanks.Mike.2015-11-02 7:35 AM
Hello Mike ,
md5sum.exe is coming from cygwin tools. PLS is using your own checksum calculation to check if the elf file has been touched and updated. Best regards Erwan
