SPC560BL1_UART_Rx_problem
Options
‎2016-05-12 7:26 PM
Posted on May 13, 2016 at 04:26
SPC560BL1 most of the time the UART Receiver is not working,we found the the UART Receiver is not triggering ,but the UART Transmitter is working always.
#spc560bl1_uart_rx_problem
Options
‎2016-05-13 1:40 AM
Posted on May 13, 2016 at 10:40
Hello Baskar ,
Often , UART Receiver and Transmitter are well validated in our tests.could you send us your example ?if you want a shell to have the interaction with the user, you can use the Output Formatter. Best Regards ErwanOptions
‎2016-05-14 5:09 AM
Posted on May 14, 2016 at 14:09Hello,The data receive from 3 uart in different timing, we can't tell timing of the data comes from uart.We are re initialization the uart every time to over come this problem,but data loss is occurred.
Options
‎2016-05-18 7:53 PM
Posted on May 19, 2016 at 04:53Is this controller not able handle multiple interrupt at the same time.
