RX interrupt with Runtime-IO
‎2021-03-18 8:31 AM
I would like to know if it possible to make RX interrupt with the serial driver initialize thanks to Runtime-IO Component RLA ?
In reality, I want to use scanf() with interrupt to make it non-blocking.
Thank you by advance
Respectfully
Bastien
‎2021-06-03 2:46 AM
Hello bastien ,
Did you asynchronous mode in Runtime -IO ?
In this particular case , often, in some big projects , i am using some multi-threads with real time os (FreeRTOS, chibios ..) in order not to block during scanf process.
Best Regards
Erwan
‎2021-06-03 2:46 AM
Hello bastien ,
Best Regards
Erwan
