Problem importing example project
alfierinicola
Posted on May 27, 2014 at 10:43
Hi, I downloaded example software SPC56EL and successfully imported all of them but then i can't get them compiled.
I don't know how to set current toolchain and current builder, keeps giving me make error about object files.
Thanks for the help!!
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
Erwan YVIN
Posted on May 27, 2014 at 11:12
Hello Nicola222,
Could you confirm SPC5Studio used version (3.0.0 or 2.0.0) ?
Anyway , normally the toolchain is present inside SPC5Studio development environment.
When you import some examples you should use ''internal'' SPC5Studio Application wizard.
(Cf Screenshot)
Could you copy-paste your error log ?
Best Regards
Erwan YVIN
________________
Attachments :
2014-05-27_110945.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qWro&d=%2Fa%2F0X0000000boY%2FcyzEs.bazgqAGj_yDdv_XFTxIgNZ69Ka9EYW7T59f8M&asPdf=false
alfierinicola
Posted on May 27, 2014 at 11:38
I'm using SPC5studio 2.0!
When I create new Application Components folder is missing in the project so that inclusion is unresolved ad i have to add it manually.
The screenshot is made importing example project!
________________
Attachments :
Immagine.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qXBB&d=%2Fa%2F0X0000000bof%2FxZk8J_fP6uX1QxV17Hb2cZLyMS94CvPLmwguDJlPOZE&asPdf=false
Erwan YVIN
Posted on May 27, 2014 at 16:29
Hello Nicola ,
it should be ok to add manually.
Have you tried to build an application from the repository ?
New ==> SPC5Studio Wizard
Could you try the last version of SPC5Studio ?
3.0 is out since yesterday.
http://www.st.com/web/en/catalog/tools/PF255702#
for your information,
To set the toolchain has no impact in C/C++ Build of the project properties
SPC5Studio is using its own toolchain (gnutools)
and Hightec compiler (ppc-vle-gcc)
Best Regards
Erwan Yvin
________________
Attachments :
2014-05-27_150920.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qWIZ&d=%2Fa%2F0X0000000boB%2F5.PwUBEbZPmeeHeE__Ad0Hwwl4baz46Y79lkQ1dazQU&asPdf=false
