2021-09-29 2:07 AM
i want to flash program to target board and also debug which is suitable for my part number and also i want to flash program to target board without PC support for industrial purpose(SPC5-UDESTK-EVAL) is this ok for my requirement
2021-09-29 6:19 AM
Hello Mano ,
I recommend to go the SPC5STudio Tools suite
There is a nice example :
SPC560Bxx_RLA Bootloader Application for Discovery
Check the document associated
Best Regards
Erwan
2021-09-29 6:19 AM
Hello Mano ,
Best Regards
Erwan
2021-10-01 2:28 AM
The problem is that SPC560Bxx_RLA Bootloader Application for Discovery is not good for spc560b50l5 because is under SPC560BCxx_RLA Bootloader Application that doens't exist. Could do ST implement SPC560BCxx_RLA Bootloader Application please.
Thank you in advantages
