2019-10-07 12:58 PM
Hi everybody,
We are currently working on a commercial project for automotive industry. Since we are used to use ST mcus, we want to continue ST's automotive grade mcu. The requirements are listed below;
- AEC-Q100 compliant
- ASILB or higher level qualification.
- At least 2xCAN peripheral
- RTC timer
- External 32 khz connection option
- At least 1 x I2C
The mcu which almost meets that requirements I found is SPC560b50l3 but I am not sure if it is compliant with AEC-Q100 and ASILB or higher qualification. Can you please confirm or recommend another ST mcu?
Thanks in advance
2019-10-31 7:42 AM
Hello ,
SPC560B50L3 is AEC-Q100 qualification compliant
For ASILB , you should use 58 family or 56L
cf link
https://www.st.com/en/automotive-microcontrollers/spc5-p-performance-mcus.html
Best regards
Erwan
2019-10-31 7:42 AM
Hello ,
cf link
Best regards
Erwan
