would you check and explain what is different in between USBLC6-2P6 and USBLC6-2P6/J
SChan.14
https://community.st.com/s/question/0D53W00000iFCiESAW/the-commercial-product-part-was-different-finished-goods-part-
P​ictured here, guessing a packaging designation or engineering rev.
5 REPLIES 5
Peter BENSCH
Where did you find the ordering code USBLC6-2P6/J?
/Peter
Hi Peter,
We have received the part as the manufacturer label showing both MPN type, so would you help to check and explain the difference, thanks,
Peter BENSCH
You didn't upload any picture.
For privacy reasons, please do not use your e-mail account to reply with an e-mail, as this will make your contact details visible to the entire community. Right now, the best way to do this is to log in with a web browser.
/Peter
The type number USBLC6-2P6 is the is the actual designation, while the suffix /J in the 2nd line is used for internal follow-up and indicates the place of manufacture.
To answer your question: no, there is no difference, it is the right device if you have ordered USBLC6-2P6.
Good luck!
/Peter
