Sep 10, 2025 5:04 AM UTC
stm32n657 how to unlock the protection program?
When using stm32cubeprogrammer to burn the program for nucleo-N657X0, the external flash kernel is locked. The inside of the external flash I read is all ffffff. When I erase the code of the external flash, it will report an error that it cannot be erased.
Julian E.
Sep 11, 2025 8:49 AM UTC
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
yzfAuthor
Sep 12, 2025 6:15 AM UTC
I have tried all the methods but still haven't found an effective solution to the problem. Now I suspect that it might be a problem with the solder joints. Could you please forward this message to others for their opinions?
