waclawek.jan
DMA not working in CubeMX generated code - order of initialization
  • December 7, 2019
  • 39 replies
  • 15198 views
Here is a (possibly incomplete) list of threads affected by this CubeMX issue:
https://community.st.com/s/question/0D50X0000BVnBhASQV/bug-report-dma-and-adc-initialization-order-changed-in-stm32f4-hal-v1241-causing-incorrect-adc-operation
https://community.st.com/s/feed/0D50X0000BZFWRISQ5
https://community.st.com/s/question/0D50X0000BbKaA5SQK/haluarttransmitdma-doesnt
https://community.st.com/s/question/0D50X0000BbMcnpSQC/dma-adc-doesnt-work
https://community.st.com/s/question/0D50X0000BWqGdtSQF/haladcstartdma-init-msp-bug
https://community.st.com/s/question/0D50X0000BcS7tSSQS/stmcubeide-110-cubemx-540-switch-initialization-order
https://community.st.com/s/question/0D50X0000Bfs7MvSQI/stm32f3-adc-with-dma-bug
https://community.st.com/s/question/0D50X0000Bh6PntSQE/bug-mxdmainit-wrongly-placed-by-code-generator-haluarttransmitdma-does-not-work
https://community.st.com/s/question/0D50X0000BiA27LSQS/code-generated-calls-mxdmainit-too-late-after-mxspiinit
https://community.st.com/s/question/0D50X0000BcPXk2SQG/32f746-usart-dma-with-stemwin-not-working
 https://community.st.com/s/question/0D50X0000BmoZgKSQU/simple-uart1-dma-dosent-work-generated-with-latest-stm32cubemx-540-and-stm32f0-1110
This is just in case somebody would like to put up a sticky post with this...
[EDIT] Further development with CubeMX5.5
https://community.st.com/s/question/0D50X0000Bwjgi7SQA/with-stm32cubemx-55-and-stm32h743-the-mxdmainit-function-is-not-called-at-the-right-time
[EDIT] Problem reappeared 6.3.0 https://community.st.com/s/question/0D53W000011uIPgSAM/adc-dmahandle-is-0
[EDIT] Official method to fix the incorrect order, if project was generated in "incorrect" version of CubeMX: https://community.st.com/s/question/0D53W00001EzCmCSAV/mxdmainit-order-in-the-mainc-file-generated-by-stm32cubemx-how-to-fix
Best answer by waclawek.jan
Here is the official method to fix the incorrect order, if project was generated in "incorrect" version of CubeMX:
Amel NASRI
OK Jan, your post is pinned on the top of STM32CubeMX questions, waiting for next release of the tool where a fix will be available :)
waclawek.jan
Thanks, Amel.
Jan
Amel NASRI
Amel NASRI
Amel NASRI
Amel NASRI
Louis Cloete work
Any place where I can see if this is fixed in the newest CubeMX?
Amel NASRI
Hi @Community member​ ,
Did you downloaded latest CubeMX version (5.6)? The issue is already fixed.
-Amel
Louis Cloete work
Thanks for the reply. I did not download it because of data usage concerns. I'll download it now that I know it is fixed.
For future reference, do you have a place where we can see the status of publicly-reported bugs? It would be very useful.
