Driver stm32_pmic2 on node stpmic2@33 failed - TEE_ERROR_ITEM_NOT_FOUND
DMårt
Lead
I have an issue with PMIC. It seems that Op-tee won't start och activate the PMIC. Do you know why? Any suggestion? The error is 0xffff0008 = TEE_ERROR_ITEM_NOT_FOUND.
Notice that I have copied the DT from DK board.
F/TC:0 0 probe_driver_node:543 Probing stm32-gpu on node gpu@48280000
D/TC:0 0 probe_driver_node:556 element: stm32-gpu on node gpu@48280000 deferred 3 time(s)
F/TC:0 0 probe_driver_node:543 Probing stm32_pmic2 on node stpmic2@33
F/TC:0 0 stm32_pmic2_probe:923 Probe stpmic2
F/TC:0 0 initialize_pmic2:893 Initialize stpmic2
F/TC:0 0 lock_i2c_bus_access:796 thread access
F/TC:0 0 unlock_i2c_bus_access:837 thread access completed
F/TC:0 0 stpmic2_register_read:259 REG[0 v=0x21
F/TC:0 0 stpmic2_register_read:259 REG[0x1 v=0x11
I/TC: PMIC STPMIC REFID:2.A V1.1
F/TC:0 0 stpmic2_register_read:259 REG[0x20 v=0x1e
F/TC:0 0 stpmic2_register_read:259 REG[0x21 v=0x1
D/TC:0 0 stpmic2_regulator_get_prop:428 buck1: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul buck1: EN, 800mV
D/TC:0 0 stpmic2_regulator_get_prop:428 buck1h: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul buck1h: EN, 1500mV
F/TC:0 0 stpmic2_register_read:259 REG[0x25 v=0x20
F/TC:0 0 stpmic2_register_read:259 REG[0x26 v=0x1
D/TC:0 0 stpmic2_regulator_get_prop:428 buck2: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul buck2: EN, 820mV
F/TC:0 0 stpmic2_register_read:259 REG[0x2a v=0
F/TC:0 0 stpmic2_register_read:259 REG[0x2b v=0
D/TC:0 0 stpmic2_regulator_get_prop:428 buck3: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul buck3: DIS, 500mV
F/TC:0 0 stpmic2_register_read:259 REG[0x2f v=0x76
F/TC:0 0 stpmic2_register_read:259 REG[0x30 v=0x1
D/TC:0 0 stpmic2_regulator_get_prop:428 buck4: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul buck4: EN, 3300mV
F/TC:0 0 stpmic2_register_read:259 REG[0x34 v=0x67
F/TC:0 0 stpmic2_register_read:259 REG[0x35 v=0x1
D/TC:0 0 stpmic2_regulator_get_prop:428 buck5: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul buck5: EN, 1800mV
F/TC:0 0 stpmic2_register_read:259 REG[0x39 v=0x3c
F/TC:0 0 stpmic2_register_read:259 REG[0x3a v=0x1
D/TC:0 0 stpmic2_regulator_get_prop:428 buck6: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul buck6: EN, 1100mV
F/TC:0 0 stpmic2_register_read:259 REG[0x3e v=0x76
F/TC:0 0 stpmic2_register_read:259 REG[0x3f v=0x1
D/TC:0 0 stpmic2_regulator_get_prop:428 buck7: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul buck7: EN, 3300mV
F/TC:0 0 stpmic2_register_read:259 REG[0x64 v=0
D/TC:0 0 stpmic2_regulator_get_prop:428 refddr: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul refddr: DIS, 0mV
F/TC:0 0 stpmic2_register_read:259 REG[0x4c v=0x1
D/TC:0 0 stpmic2_regulator_get_prop:428 ldo1: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul ldo1: EN, 1800mV
F/TC:0 0 stpmic2_register_read:259 REG[0x4f v=0x31
D/TC:0 0 stpmic2_regulator_get_prop:428 ldo2: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul ldo2: EN, 3300mV
F/TC:0 0 stpmic2_register_read:259 REG[0x52 v=0x13
D/TC:0 0 stpmic2_regulator_get_prop:428 ldo3: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul ldo3: EN, 1800mV
F/TC:0 0 stpmic2_register_read:259 REG[0x55 v=0x1
D/TC:0 0 stpmic2_regulator_get_prop:428 ldo4: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul ldo4: EN, 3300mV
F/TC:0 0 stpmic2_register_read:259 REG[0x58 v=0
D/TC:0 0 stpmic2_regulator_get_prop:428 ldo5: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul ldo5: DIS, 900mV
F/TC:0 0 stpmic2_register_read:259 REG[0x5b v=0
D/TC:0 0 stpmic2_regulator_get_prop:428 ldo6: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul ldo6: DIS, 900mV
F/TC:0 0 stpmic2_register_read:259 REG[0x5e v=0x1
D/TC:0 0 stpmic2_regulator_get_prop:428 ldo7: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul ldo7: EN, 900mV
F/TC:0 0 stpmic2_register_read:259 REG[0x61 v=0
D/TC:0 0 stpmic2_regulator_get_prop:428 ldo8: get prop 2
D/TC:0 0 stpmic2_dump_regulators:585 PMIC regul ldo8: DIS, 900mV
F/TC:0 0 initialize_pmic2_irq:787 Init stpmic2 irq
F/TC:0 0 stm32mp2_pwr_itr_dt_get:341 Pwr IRQ add
F/TC:0 0 stm32_pwr_irq_set_trig:162 irq:0 falling edge
E/TC:0 0 probe_driver_node:565 Failed to probe stm32_pmic2 on node stpmic2@33: 0xffff0008
D/TC:0 0 process_probe_list:697 Unresolved dependencies after 5 rounds, 4 deferred
D/TC:0 0 probe_dt_drivers_early:883 Deferred drivers probing
 My DT for op-tee is:
/dts-v1/;
#include <dt-bindings/pinctrl/stm32-pinfunc.h>
#include <dt-bindings/clock/stm32mp25-clksrc.h>
#include "stm32mp257.dtsi"
#include "stm32mp25xf.dtsi"
#include "stm32mp257f-firmware-mx-rcc.dtsi"
#include "stm32mp257f-firmware-mx-resmem.dtsi"
#include "stm32mp257f-firmware-mx-rif.dtsi"
#include "stm32mp25xxak-pinctrl.dtsi"
/* USER CODE BEGIN includes */
/* USER CODE END includes */
        model = "STMicroelectronics custom STM32CubeMX board - openstlinux-6.6-yocto-scarthgap-mpu-v26.02.18";
        compatible = "st,stm32mp257f-firmware-mx", "st,stm32mp257";
        memory@80000000 {
                device_type = "memory";
                reg = <0x0 0x80000000 0x0 0x80000000>;
                /* USER CODE BEGIN memory */
                /* USER CODE END memory */
        /* USER CODE BEGIN root */
        aliases {
                serial0 = &usart6;
        chosen {
                stdout-path = "serial0:115200n8";
        /* USER CODE END root */
}; /*root*/
&pinctrl {
        i2c7_pins_mx: i2c7_mx-0 {
                pins {
                        pinmux = <STM32_PINMUX('D', 14, AF10)>, /* I2C7_SDA */
                                         <STM32_PINMUX('D', 15, AF10)>; /* I2C7_SCL */
                        bias-disable;
                        drive-open-drain;
                        slew-rate = <0>;
        pwr_pins_mx: pwr_mx-0 {
                pins {
                        pinmux = <STM32_PINMUX('A', 0, ANALOG)>; /* PWR_WKUP1 */
        /* USER CODE BEGIN pinctrl */
        /* USER CODE END pinctrl */
&pinctrl_z {
        /* USER CODE BEGIN pinctrl_z */
        /* USER CODE END pinctrl_z */
&bsec {
        status = "okay";
        /* USER CODE BEGIN bsec */
        /* USER CODE END bsec */
&hpdma1 {
        status = "okay";
        /* USER CODE BEGIN hpdma1 */
        /* USER CODE END hpdma1 */
&hpdma2 {
        status = "okay";
        /* USER CODE BEGIN hpdma2 */
        /* USER CODE END hpdma2 */
&hpdma3 {
        status = "okay";
        /* USER CODE BEGIN hpdma3 */
        /* USER CODE END hpdma3 */
&i2c7 {
        pinctrl-names = "default";
        pinctrl-0 = <&i2c7_pins_mx>;
        status = "okay";
        /* USER CODE BEGIN i2c7 */
        pinctrl-names = "default", "sleep";
        pinctrl-0 = <&i2c7_pins_a>;
        pinctrl-1 = <&i2c7_sleep_pins_a>;
        i2c-scl-rising-time-ns = <185>;
        i2c-scl-falling-time-ns = <20>;
        clock-frequency = <400000>;
        status = "okay";
        #address-cells = <1>;
        #size-cells = <0>;
        pmic2: stpmic2@33 {
                compatible = "st,stpmic2";
                reg = <0x33>;
                interrupts-extended = <&exti1 52 IRQ_TYPE_EDGE_FALLING>;
                wakeup-source;
                st,pmic-it-id = <IT_PKEY_FA IT_PKEY_RI>;
                st,notif-it-id = <0 1>;
                status = "okay";
                regulators {
                        compatible = "st,stpmic2-regulators";
                        ldo1-supply = <&vddio_pmic>;
                        vddcpu: buck1 {
                                regulator-name = "vddcpu";
                                regulator-min-microvolt = <800000>;
                                regulator-max-microvolt = <910000>;
                                regulator-always-on;
                                st,pwrctrl-sel = <2>;
                                st,pwrctrl-enable;
                                default {
                                        regulator-off-in-suspend;
                                lplv {
                                standby {
                                off {
                        vddcore: buck2 {
                                regulator-name = "vddcore";
                                regulator-min-microvolt = <820000>;
                                regulator-max-microvolt = <820000>;
                                st,pwrctrl-sel = <1>;
                                st,pwrctrl-enable;
                                default {
                                        regulator-on-in-suspend;
                                        regulator-suspend-microvolt = <820000>;
                                lplv {
                                        regulator-suspend-microvolt = <670000>;
                                standby {
                                off {
                        vddgpu_pmic: buck3 {
                                regulator-name = "vddgpu_pmic";
                                regulator-max-microvolt = <900000>;
                                regulator-over-current-protection;
                                standby {
                                off {
                        vddio_pmic: buck4 {
                                regulator-name = "vddio_pmic";
                                regulator-min-microvolt = <3300000>;
                                regulator-max-microvolt = <3300000>;
                                st,mask-reset;
                                st,pwrctrl-enable;
                                default {
                                        regulator-suspend-microvolt = <3300000>;
                                lplv {
                                standby {
                                off {
                                        /* ToDo: switch to LP */
                        v1v8: buck5 {
                                regulator-name = "v1v8";
                                regulator-min-microvolt = <1800000>;
                                regulator-max-microvolt = <1800000>;
                                st,pwrctrl-enable;
                                default {
                                        regulator-suspend-microvolt = <1800000>;
                                lplv {
                                standby {
                                off {
                        vdd2_ddr: buck6 {
                                regulator-name = "vdd2_ddr";
                                regulator-min-microvolt = <1100000>;
                                regulator-max-microvolt = <1100000>;
                                st,pwrctrl-enable;
                                default {
                                        regulator-suspend-microvolt = <1100000>;
                                lplv {
                                standby {
                                off {
                        v3v3: buck7 {
                                regulator-name = "v3v3";
                                st,pwrctrl-enable;
                                default {
                                lplv {
                                standby {
                                off {
                        vdda1v8_aon: ldo1 {
                                regulator-name = "vdda1v8_aon";
                                st,alternate-input-source;
                                st,mask-reset;
                        vdd_emmc: ldo2 {
                                regulator-name = "vdd_SD_card_temporary";
                                st,pwrctrl-sel = <3>;
                                st,pwrctrl-reset;
                        vdd1_ddr: ldo3 {
                                regulator-name = "vdd1_ddr";
                                st,pwrctrl-enable;
                                default {
                                lplv {
                                standby {
                                off {
                        vdd3v3_usb: ldo4 {
                                regulator-name = "vdd3v3_usb";
                                standby {
                                off {
                        v5v_hdmi: ldo5 {
                                regulator-name = "v5v_hdmi";
                                regulator-min-microvolt = <5000000>;
                                regulator-max-microvolt = <5000000>;
                                st,regulator-bypass-microvolt = <5000000>;
                                st,pwrctrl-sel = <0>;
                                st,pwrctrl-enable;
                        v5v_vconn: ldo6 {
                                regulator-name = "v5v_vconn";
                                regulator-min-microvolt = <4000000>;
                                regulator-max-microvolt = <4000000>;
                                st,regulator-bypass-microvolt = <4000000>;
                                st,pwrctrl-reset;
                        vdd_sdcard: ldo7 {
                                regulator-name = "vdd_sdcard";
                                st,regulator-bypass-microvolt = <3300000>;
                                st,pwrctrl-reset;
                        vddio_sdcard: ldo8 {
                                regulator-name = "vddio_sdcard";
                                st,pwrctrl-reset;
        /* USER CODE END i2c7 */
&ltdc {
        status = "okay";
        /* USER CODE BEGIN ltdc */
        /* USER CODE END ltdc */
&m33_rproc {
        status = "okay";
        /* USER CODE BEGIN m33_rproc */
        /* USER CODE END m33_rproc */
&pwr {
        pinctrl-0 = <&pwr_pins_mx>;
        status = "okay";
        /* USER CODE BEGIN pwr */
        status = "okay";
        wakeup-gpios = <&gpioa 0 GPIO_ACTIVE_HIGH>, <0>, <0>, <0>, <0>, <0>;
        vdd33ucpd: vdd33ucpd {
                status = "okay";
                vdd33ucpd-supply = <&vdd3v3_usb>;
        vdda18adc: vdda18adc {
                status = "okay";
                vdda18adc-supply = <&v1v8>;
        vddgpu: vddgpu {
                status = "okay";
                vddgpu-supply = <&vddgpu_pmic>;
        vddio1: vddio1 {
                status = "okay";
                vddio1-supply = <&vddio_sdcard>;
        vddio2: vddio2 {
                status = "okay";
                vddio2-supply = <&v1v8>;
        vddio3: vddio3 {
                status = "okay";
                vddio3-supply = <&vddio_pmic>;
        vddio4: vddio4 {
                status = "okay";
                vddio4-supply = <&vddio_pmic>;
        vddio: vddio {
                status = "okay";
                vdd-supply = <&vddio_pmic>;
        /* USER CODE END pwr */
&rcc {
        status = "okay";
        /* USER CODE BEGIN rcc */
        clocks = <&clk_hse>, <&clk_hsi>, <&clk_lsi>, <&clk_msi>, <&clk_i2sin>;
        clock-names = "clk-hse", "clk-hsi", "clk-lsi", "clk-msi", "clk-i2sin";
        st,c1msrd = <2>;
        st,clk_opp {
                st,ck_cpu1 {
                        cfg_1 {
                                hz = <1500000000>;
                                st,pll = <&pll1_cfg_1500Mhz>;
                        cfg_2 {
                                hz = <1200000000>;
                                st,pll = <&pll1_cfg_1200Mhz>;
                st,ck_gpu {
                        cfg_1 {
                                hz = <800000000>;
                                st,pll = <&pll3_cfg_800Mhz>;
                        cfg_2 {
                                hz = <900000000>;
                                st,pll = <&pll3_cfg_900Mhz>;
        /* USER CODE END rcc */
&risaf5 {
        status = "okay";
        /* USER CODE BEGIN risaf5 */
        /* USER CODE END risaf5 */
&vrefbuf {
        status = "okay";
        /* USER CODE BEGIN vrefbuf */
        /* USER CODE END vrefbuf */
/* USER CODE BEGIN addons */
&tamp {
        status = "disable";
/* USER CODE END addons */
STM32MP151AAC3 custom board with STM32-OS as operating system: https://github.com/DanielMartensson/STM32-Computer
STM32MP257FAK3 custom board with STM64-OS as operating system: https://github.com/DanielMartensson/STM64-Computer
Hi @Olivier GALLIEN
Here is the answer: The problem was that the interrupt was not enabled for PMIC inside the DT!
Once the interrupt GPIO was correct, then the error disapear.
Olivier GALLIEN
Hi @DMårt ,
If you are working on customer HW closed to DK using DT related to DK I invite you to cross check with your hardware if any little difference may explain issue you are facing
Olivier
Olivier GALLIEN
Hi @Olivier GALLIEN
