STM32WB55XX - No additional services.
Ofer
Hi
I tried using the P2P_SERVER profile of the STM32WB55XX example (with atollic).
When pushing on CONNECT on my mobile, I expect seeing the LED and BUTTON services as written in the example documents, but I see the 2 PRIMARY SERVICES (Generic Attribute and Generic Access as can be seen in the attached file) only, should I modify the code to make it work ?
0 REPLIES 0
