Chrom-ART Transparent rectangles / fills?
contact239955_st
Posted on March 21, 2018 at 20:20
Hi, I've been working on a UI for past couple weeks,
I've successfully created functionality for drawing bitmaps (with or without alpha), anti-aliased fonts and solid rectangles / lines using Chrom-ART / DMA2D
I am however currently unsure how to do rectangle fills with transparency. I assumed that DMA2D_R2M would accept a ARGB color and layer configurations, however that was not the case.
Can someone explain in rough lines how I can fill a rectangle, that contains an alpha channel, over an existing drawn area?
http://preview.ibb.co/htzuzc/IMG_20180321_202jpg
My current bitmap/font character drawing function:
void
LCD
DMA_DrawBitmap
void
*pSrc
void
*pDst
uint32_t
xSize
uint32_t
ySize
uint32_t
ColorMode
uint32_t
inputAlpha
uint32_t
inputOffset) {
hDma2dHandler
Init
Mode
DMA2D_M2M_BLEND
hDma2dHandler
Init
ColorMode
hLtdcHandler
LayerCfg
0
PixelFormat
hDma2dHandler
Init
OutputOffset
SCREEN_WIDTH
- xSize
hDma2dHandler
LayerCfg
0
AlphaMode
DMA2D_NO_MODIF_ALPHA
hDma2dHandler
LayerCfg
0
InputColorMode
hLtdcHandler
LayerCfg
0
PixelFormat
hDma2dHandler
LayerCfg
0
InputAlpha
0
hDma2dHandler
LayerCfg
0
InputOffset
SCREEN_WIDTH
- xSize
/* Foreground Configuration */
hDma2dHandler
LayerCfg
1
AlphaMode
hDma2dHandler
LayerCfg
1
InputAlpha
= inputAlpha
hDma2dHandler
LayerCfg
1
InputColorMode
= ColorMode
hDma2dHandler
LayerCfg
1
InputOffset
= inputOffset
hDma2dHandler
Instance
DMA2D
/* DMA2D Initialization */
if
(HAL_DMA2D_Init(&
hDma2dHandler
HAL_OK
if
(HAL_DMA2D_ConfigLayer(&
hDma2dHandler
0
HAL_OK
&& HAL_DMA2D_ConfigLayer(&
hDma2dHandler
1
HAL_OK
if
(HAL_DMA2D_BlendingStart(&
hDma2dHandler
uint32_t
) pSrc
uint32_t
) pDst
uint32_t
) pDst
xSize
ySize) ==
HAL_OK
HAL_DMA2D_PollForTransfer(&
hDma2dHandler
500
And rectangle fill function:
void
LCD
DMA_FillRect
void
*pSrc
void
*pDst
uint32_t
xSize
uint32_t
ySize
uint32_t
ColorMode) {
/* Configure the DMA2D Mode, Color Mode and output offset */
hDma2dHandler
Init
Mode
DMA2D_M2M_PFC
hDma2dHandler
Init
ColorMode
hLtdcHandler
LayerCfg
0
PixelFormat
hDma2dHandler
Init
OutputOffset
SCREEN_WIDTH
- xSize
hDma2dHandler
LayerCfg
1
AlphaMode
hDma2dHandler
LayerCfg
1
InputAlpha
0xFF
hDma2dHandler
LayerCfg
1
InputColorMode
= ColorMode
hDma2dHandler
LayerCfg
1
InputOffset
0
hDma2dHandler
Instance
DMA2D
if
(HAL_DMA2D_Init(&
hDma2dHandler
HAL_OK
if
hDma2dHandler
1
HAL_OK
if
(HAL_DMA2D_Start(&
hDma2dHandler
uint32_t
) pSrc
uint32_t
) pDst
xSize
ySize) ==
HAL_OK
hDma2dHandler
500
graphics lcd ui chrom-art dma2d
5 REPLIES 5
contact239955_st
Posted on March 26, 2018 at 13:38
Anyone?
Tilen MAJERLE
Posted on March 26, 2018 at 13:42
Hello
Sleziak.Marcin
R2M with blending is directly not supported. However, you can do these steps:
  1. Use R2M mode and fill your rectangle memory outside layers
  2. Perform M2M with blending
    1. For front layer set memory of your rectangle you just filled
    2. For back layer set memory position where you want to put your rectangle
    3. Set front layer alpha for transparency value of whole layer
Best regards,
Tilen
Tilen MAJERLE
Posted on March 26, 2018 at 13:50
Hello
Sleziak.Marcin
this is the only way. Any operation with transparency is normally done in pixel2pixel conversion between 2 memory addresses (2 layers), thus R2M_Blending mode is not supported and alpha channel is ignored.
Which STM32 do you use in this project?
Best regards,
Tilen
Posted on March 26, 2018 at 13:48
Hi
Majerle.Tilen
, thank you for your reply!
That's currently the work-around I'm using, however this requires me to have a 3rd buffer allocated just for transparent rectangle fill operations.
Is this something that is technically not possible or just not documented?
Best wishes,
Posted on March 26, 2018 at 13:56
All right, that makes sense.
I'll try to optimize my 3rd buffer memory usage by using A4 color mode + a CLUT (If that makes sense?).
I'm using the F746
Best wishes,
