STM32F4 DOC HELP !
petre
Posted on April 14, 2013 at 10:20
Hello everybody,
Where can I find the documentation (user manual) for the STM32F407VG core from the discovery board ? The doc needs to have all the registers for the core and peripherals :) a NORMAL user manual...
Thanks a lot !
Mihai P
#lmgtfy:-stm32-resources
raptorhal2
Lead
Posted on April 14, 2013 at 14:38
http://www.st.com/web/en/catalog/mmc/FM141/SC1169
This link will get you to the index to all STM32 documentation.
Cheers, Hal
Posted on April 14, 2013 at 15:03
ST has four basic manuals
A Data Sheet/Manual for a specific part with pin designations (STM32F407VG).
A Reference Manual for a family of parts (F4), RM0090, with peripheral registers
A Programming Manual for the flash memory.
A Programming Manual for the Cortex-M4, this describes the core, you could also pull the ARM TRM
Let's say we Google ''STM32F407VG''
First hit
http://www.st.com/web/catalog/mmc/FM141/SC1169/SS1577/LN11/PF252140
The data sheet is listed here
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/DM00037051.pdf
Go to the ''Design Resources'' tab
At the top is the Data Sheet again
Scroll down further for
Reference Manual
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/reference_manual/DM00031020.pdf
Programming Manual
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/programming_manual/DM00023388.pdf
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/programming_manual/DM00046982.pdf
