STM3210C_eval evaluation board use Fatfs- f_getfree() functino
robbie
Posted on December 31, 2015 at 05:16
Hi guys,
I used AC6 system workbench to development STM3210C_eval evaluation board.
Now I try to use Fatfs to get SD card Capacity->res = f_getfree(''0:/'', &fre_clust, &fs);
In debug mode, I get:
Details:FR_DISK_ERR
Default:FR_DISK_ERR
Decimal:1
Hex:0x1
Binary:1
Octal:01
what's happened? Does someone can help me?
Thank all.
Posted on December 31, 2015 at 05:25
Ok, and you've mounted the media? Any of the other access functions work? ie can you open and read a file?
Have you tested your SD access functions outside of diskio.c? Can you instrument the routines in diskio.c to see which are succeeding, and which are failing?
robbie
Posted on January 06, 2016 at 11:00
Thanks for your reply.
I fix it off.
Before use Fatfs Functions, it should f_mount() first.
