Newbe to stm32, need to write a bootloader for CAN
sima
Posted on January 21, 2010 at 03:20
28 REPLIES 28
szymon_stroba
Posted on May 17, 2011 at 13:05
The problem was that I was jumping to user application from interrupt handler. Thanks for all Your help.
ralph2
I'm having the same problem switching from a bootloader to an application (I get a fault at the first SVCall instruction in the application). Can you share the details of your fix with us?
Thanks.
Ralph
Quote:
sima
:D
tomas23
Do you map the vector table and stack pointer of new appication properly? See the hints in previous posts.
tim239955_st
Try posting your text in the body of the message, not in the tags.
awillems
Posted on January 13, 2012 at 16:09
Hello Sima1,
  CAN you help, I've the same problem as had, I've to develop a bootloader(IAP) over CAN.
Kind regards
redkofka
Posted on July 10, 2012 at 14:27
Hi , I am going to write custom bootloader to all i need is simplest example for stm32 about that you was talking....have you any idea where can i find them ?
Posted on July 10, 2012 at 16:40
Start with AN2557, understand the mechanics
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/APPLICATION_NOTE/CD00161640.pdf
