iec62056-21
ap.1
hello guys does anyone have a implantation of iec6256-21 for st mcus ??
i saw a pdf from st that suggested Andreas anformatique implantation but i couldnt find it
note: im looking for a library for server or metering device side not for handheld device side
Peter BENSCH
Your favourite search engine would probably find hits like this one.
Does it answer your question?
/Peter
thank you sir for your reply I saw that link a while ago this iec standard have two devices handheld device and metering device the library that you provided a link for it is for handheld device but im looking for metering device side library , I should have explained more precisely on topic , if you know any other source for metering device that would be wonderful
