External flash proggramming using GDB server
echelon2010
Posted on November 07, 2015 at 08:10
Hello. I have a board with STM32f746IG controller and S25FL128S qspi NOR-flash memory. I'd like to program my code using GDB server. How to do this? I've never done this before. I also want to use GDB server for debugging. Is it possible with the code located in external flash? Thank you
0 REPLIES 0
