DS18B20 1Wire DMA
amir_lm35
Posted on October 26, 2016 at 09:31
Hi All...
i using stm32f103rbt and Ds18B20 temp sensor.
i search for hardware peripheral driver that make 1wire independent from cpu but not find any thing useful.
i want to read temp from ds18b20 without delay. how it is possible?
thanks a lot.
ColdWeather
Posted on October 26, 2016 at 10:46
It's not quite clear, what you mean under ''CPU independent'' exactly, but I can suggest for the case a
https://www.maximintegrated.com/en/products/interface/controllers-expanders/DS2484.html
: an I2C to 1-Wire interface. Having I2C, it makes the 1-Wire access CPU independent in some kind.
Uwe Bonnes
Chief
Posted on October 26, 2016 at 12:15
Your question is not clear!
But you can generate the needed waveform for One-Wire communication by Uart.
Look at Maxim application note AN126. That way, timing is done independant from CPU.
