Data logger
udibit
Posted on July 13, 2015 at 14:26
I would like to use micro-SD to log data of several sensors.
(I have connected micro-SD to my STM32F103 nucleo board, and I am  able to open and write into a file).
1. In order to add new data (16bit), i just use ''f_write'', is there more appropriate function?
2. How can i check if a new file name is already exist?
3. Can someone refer me to such example code?
Thanks - Udi.
Posted on July 14, 2015 at 18:11
Don't f_write() 16-bits at a time, buffer much larger blocks of data.
You can use various forms of f_open(), with FA_OPEN_ALWAYS you can check fil.fsize, and f_lseek() to the end if you want to append to an existing file.
You could use f_open() with FA_READ and see if you get an error, or not?
You could also use f_opendir/f_readdir to check what files exist
The FatFS website seems to provide sufficient examples and documentation to get things done.
