2026-05-29 12:02 PM
I am using the B-L475E-IOT01A Discovery kit with tutorial, "Tutorial: Use Eclipse ThreadX to connect an STMicroelectronics B-L475E-IOT01A Discovery kit to IoT Hub".
A few months ago when I first tried to connect to the IOT Hub, which was running TLSv1.0, worked fine.
Now Azure is forcing devices to use TLSv1.2 with a strong cipher suite such as
per https://learn.microsoft.com/en-us/azure/iot-hub/iot-hub-tls-support.
I enabled the following:
