2024-04-03 5:20 PM
Hi
I am using ST25DV04KC tag in my product. During EN300330 test, there is a very high 2nd harmonic component radiated and exceeds the limit when the NFC reader is placed beside the tag. Anyone encounter this issue before?
For Type-5 tag, is it normal to see a high 2nd harmonic component during communication with the reader?
Thanks.
Rgds
Dan
2024-04-04 12:44 PM
Hi All,
This question has been routed to our online support center for direct assistance.
Jake
ST Support
2024-04-04 8:48 AM
It is difficult to comment because each configuration is different, however I can share some of the observations we did when certifying our boards.
We saw that changing the power supply and/or the usb cable to power the board can impact the results. Also we saw that the reader used for the test, can have an impact. We have used the ST25R3911B-Disco board as a reader and it was working fine.
2024-04-04 12:44 PM
Hi All,
Jake
ST Support
