2018-12-05 2:28 AM
2018-12-10 11:46 PM
The file identifiers are contained in the DS chapter 3.1.1
Best Regards,
BB
2018-12-06 5:55 AM
First of all, thanks for your interest in ST25TA16K product !
Then, In the NFC Forum Type 4 standard, you have to apply a "select file" or a "select application" command before any read or write command. If you get the error code corresponding to "file or application not found" this means :
1) you do not have sent this kind of command
or
2) the reference of the file or application you have tried to select is wrong.
I hope this answer your question,
Best Regards,
BB
2018-12-06 8:15 PM
How i can assure the reference of the file is correct.....
2018-12-10 11:46 PM
Best Regards,
BB
