Floating point emulation and stack
ewitt
Posted on September 14, 2006 at 08:38
ewitt
Hi @all!
In one of my posts before I told u about a problem with floats when returning back to a ISR.
Assume that u have a function using float variables. From that function you call a second function also receiving and/or returning floating point variables. Because the emulation of both floats is running in the same memory the float variables get filled up with random values.
I prevented this behaviour by inlining the functions manipulating float.
Now i want to know if there is another way to solve this problem? (Expect inlining and working with fixed point aritmethic)
greets,
Erwin
