1.8v Digital Power supply for accelerometer
dsouzahansen
Posted on April 09, 2011 at 20:49
   Could someone tell me what is the reason for having a 1.8V supply for the digital I/O of the accelerometer.One reason Im guessing could be lower power consumption and compatibility with lower voltage peripherals but in this case the MCU on INEMO board is running at 3.3volts.
Hansen
#inemo
dsouzahansen
Posted on April 18, 2011 at 11:26
I believe its because the MAG digital IOs work at max 2.0 volt
nguyenvanhiep_hd1985
Posted on August 29, 2011 at 10:33
But you can use 3.3V to supply for it
