S2LP with external PA?
NAwari
Is there any available circuit/schematic where external PA has been used to enhance the power output of S2LP at 868 MHz operations? I am trying to understand how do I work around BALUN suggested for S2LP 868 MHz (FKI868V2 kit) with an external PA?
Ulysses HERNIOSUS
Reformatted and moved to proper Q&A (topic is not about ST25 products).
Winfred LU
NAwari
Hi Winfred,
Thanks for the answer.
Can I also know if it is possible to observe data transmitted in Tx modeofS2LP on the oscilloscope? Or is there any way to observe this data which is sent on air?
best,
Nilesh
