Hello, I'm doing interference tests with wifi and BlueNRG-LP Prop. Is there a value how much higher the signal of the BlueNRG-LP has to be to overpower Wifi? Regards
Thomas1s
WiFi uses significantly higher output power. I assume that the WiFi signal is perceived as noise by the BlueNRG. (Please correct me if I am wrong.) To receive a signal from a second BlueNRG-LP, the received msg signal strength must be higher than the WiFi noise. Am I right? If so, how much higher must this signal be? x dBm?
Thanks a lot!
0 REPLIES 0
